gas solid fluidizd bed with cfx
Old   November 21, 2007, 05:32
Default gas solid fluidizd bed with cfx
mohamad
how can i model a gas solid fluidized bed with ansys cfx? i dont have injection of particles but a static bed at minimum fluidization velocity i can not define solid particles in the domain
Old   November 26, 2007, 13:58
Default Re: gas solid fluidizd bed with cfx
Ribeiro
Hi Mohamad
You can set your bed through solid volume fraction initial Condition. You may use CEL's step function such that
step((z-0.5[m])/1[m])
assuming your gravity parallel to z and bed heigth (from z=0) of 0.5 m.
Hope this helps
Old   November 27, 2007, 03:03
mohamad
hi Ribeiro I am not familiar with cel expression very much.when i make a new expression as "step((z-0.5[m])/1[m])"how can i use it in my simulation. thank you
Old   November 27, 2007, 07:24
Ribeiro
You gonna give this expression a name, right? So you can write it in any space through out the setup where the "root of alpha" buttom is present.
For this particular case you should go in Global Initialization (or in Domain tab called Initialization), change the option of solid volume fraction to 'Automatic with Value'. Then click on "root of alpha" buttom and write the name of CEL expression. It is pretty easy.
Good luck.
Old   December 2, 2007, 03:20
mohamad
the problem is when i use "particle tracking" i can not find particle volume fraction option in initialization tab???????
Old   July 28, 2010, 15:15
Germán González Silva
germangsilva is on a distinguished road
Send a message via MSN to germangsilva
hello
I'm doing studies of fluidization (gas-solid), I'm using cfx11 or 12, and applying LES, but I have great difficulty setting the program cfx, I ask your help, please. my email is germangsilva@gmail.com.
with Regards
germangsilva is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Basic advice on Importing Solid Edge model to CFX needed. stephen__white CFX 1 February 9, 2011 18:40
Gas solid flow in a pipe with 90 bend pandaba FLUENT 0 September 14, 2010 01:43
Dispersed Solid particles in carrier gas (DPM) Frederik FLUENT 1 June 3, 2008 05:13
gas solid flow in a pipe Pandu CFX 0 July 30, 2001 16:53
