March 10, 2023, 08:22 |
Time average pressure in CFX Pre
In transient simulation I have in the midle of the domaim mass flow outlet. The mass flow is definied by simple proportional equation based on the pressure at this outlet. I defined this function using expression and areaAve(Pressure). However to improve the convergence I would like to use the time average pressure at this outlet. I am not sure how to defined it or if it is even possible. I would a appreciate any suggestions.
Thank you |
March 10, 2023, 20:45 |
Rep Power: 143 |
Not sure if you can do this, but have a look in the documentation about time averaged results (in the output tab of CFX-Pre) and the CFX Reference guide CEL variables - you have a .trnavg modifier which might do what you want.
cfx-pre setup, expressions |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
