convegence accelerated ?
Old   February 28, 2008, 14:10
Default convegence accelerated ?
amine
HI i want to know if we can accelerate a convergence ( reduce the iteration number ) without affecting the physical meaning a the results,in this case how?
Old   February 28, 2008, 16:23
Default Re: convegence accelerated ?
This is discussed in the manual. For a steady state simulation you use the timestep size as the acceleration parameter.
Old   February 28, 2008, 19:04
amine
hi thanks alots Glenn,i have to do it because you've answered to many of my questions. actual i know that parameter,i think that a larger timestep would accelerate the convergence,but would it affect the result ( i mean the physical one),CFX compute the the auto,to which extend can i deviate from.
thanks again.
Old   March 1, 2008, 09:47
Hekler
A converged solution does NOT depend on the timestep. Choose a value that gives you optimal convergence.
Old   March 1, 2008, 17:15
amine
i haven't understood?,thanks
Old   March 2, 2008, 17:11
A converged steady state solution will not change no matter how large or small the timestep. The psuedo-time terms go to zero. As Hekler says, you adjust the timestep to get optimal convergence for your simulation.
If you are finding the timestep size is changing the solution then you have a problem in your simulation.
accelerated flow mike CFX 10 October 23, 2021 05:52
Corrugated pipe, accelerated flow kjetil OpenFOAM Running, Solving & CFD 0 February 1, 2011 09:55
dynamic mesh - sphere falling through fluid volume accelerated by gravity onely. alexmeier FLUENT 1 June 26, 2010 08:33
Meshing and convegence the tangenbtial Cyclone esicia FLUENT 0 November 10, 2009 16:14
Turbulent Decay in Strongly Accelerated Flows Jonas Larsson Main CFD Forum 3 April 29, 2003 06:32
