Update failed for the Solution component in Fluid Flow (CFX). The solver failed with |
December 27, 2023, 02:43 |
Ihsan Maulana
Rep Power: 2 |
Hello everyone, I am doing a multiphase simulation in CFX to determine the friction resistance on the plate when injected with an air bubble through the water. The issue I am encountering is an update failure for the Solution component in Fluid Flow (CFX). The solver failed with a non-zero exit code of 2. How can I resolve this problem?
http://https://drive.google.com/driv...e6TgIiXj3F_OCM |
December 27, 2023, 04:41 |
Rep Power: 143 |
The error messages at Workbench level as not very useful. The useful error messages are contained int he output file. Please attach your output file - and do not use links to third party sites (your link appears broken anyway) - attach the output file directly to the forum as described here: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
January 4, 2024, 12:12 |
#3 | |
Ihsan Maulana
Rep Power: 2 |
January 4, 2024, 12:16 |
#4 | |
Ihsan Maulana
Rep Power: 2 |
2.jpg post forum.jpg Last edited by ihsanmm; January 4, 2024 at 12:18. Reason: wrong |
January 4, 2024, 13:23 |
Rep Power: 33 |
You need to extract the Ansys CFX Solver output file from Workbench, and post it here. In particular, the last section of the file is where the original, and hopefully more detailed, error message should be.
air bubble, cfx, resistance |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
CFX Update failed for the Solution component. SEC crashed? | ClarPer | CFX | 4 | December 7, 2016 12:49 |
[ANSYS Meshing] Update failed for the Mesh component in Fluid Flow (Fluent). | iankasai | ANSYS Meshing & Geometry | 2 | October 15, 2016 15:00 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
