Convergence problem in mixing chamber
Old   March 7, 2008, 04:35
Default Convergence problem in mixing chamber
SG
Hello everyone.
I have a convergence problem in a mixing chamber. flow is injected into chamber from a big inlet port and 4 small inlet ports.(Inlet B.C. = 40, 30, 20, 10 bar) each of injected flows are merged in mixing chamber and discharged into a discharging nozzle.(Outlet B.C. = 1atm)
In case of low pressure inlet condition(10bar), simulation was well converged with any mesh size and turbulence models. In case of high pressure inlet condition(40,30bar), however, continuity, k and epsilon are diverged.(different mesh size and turbulence models)
Although I changed pressure inlet condition to mass flow rate inlet condition, simulation result was diverged.
How can i solve this problem?
Thank you in advance.
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
convergence problem in comsol anderson COMSOL 0 February 24, 2008 16:54
