February 25, 2008, 01:52 |
strouhal number
Does anyone knows how to find the Strouhal number in Post-CFX? I am modelling constant flow past a cylinder, and wants to figure out the Strouhal number of that flow? Any ideas guys? Thanks a lot. Deloat |
February 25, 2008, 05:08 |
Re: strouhal number
Just plot a chart of pressure behind the cylinder vs. time and estimate the period of the variation? Use that to compute the shedding frequency. I assume you know the radius and velocity already - so together that should allow you to compute the Strouhal number. I don't think there's much more to it....
(By the way be careful to account for the fact that with alternate vortex shedding from each side of the cylinder, the frequency of the drag force variation is twice that of the lift force variation...) Good luck, Andy |
February 25, 2008, 06:02 |
Re: strouhal number
Trying using Origin 7.5 software to extract this frequency!
February 25, 2008, 09:23 |
Re: strouhal number
What I do is plot the vorticity and set the scale so I can see the vortex better. Then I do an animation and export the frames as images. Then all I have to do is match 2 frames. Since my timesteps are constant, I have the time between two identical frames.
February 27, 2008, 14:11 |
Re: strouhal number
I believe Strouhal number is only used when the flow is oscillatory. If you are modeling with constant flow then it wont help.
March 11, 2008, 03:19 |
Re: strouhal number
dear pasu
But there is a defenition of strouhal number for constant flow also the frequency as vortex shedding frequency and diameter as length scale for a given velocity. |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
