Understanding CFX Force Calculations on a Wall Due to Shear |
February 21, 2024, 03:13 |
Fabio Asaro
Rep Power: 5 |
Hello everyone
This question has also been posted in the CFD subreddit: https://www.reddit.com/r/CFD/comment...ons_on_a_wall/ I am running a easy test case with the aim to understand better how CFX calculates the force acting on a wall due to shear. To this end, I set up a basic scenario involving a small cube placed within a channel. The channel's walls, moving at a velocity of 1m/s (matching the inlet velocity). For this test, I conducted a stationary simulation using the SST turbulence model. My focus was on analyzing the force acting in x direction exerted on the cube's right side (as highlighted in the accompanying image). To evaluate the force, I employed three distinct methods (see table). Interestingly, the first two methods produced nearly identical results. However, calculating the wall shear stress directly through the formula led to a significantly different value. This discrepancy has led me to wonder: Is there an error in my formula, or does CFX employ a unique approach when calculating wall shear stress? I'm eager to hear your insights or any similar experiences you might have had. Your feedback would be greatly appreciated. Thank you in advance for your help! Backround: Perhaps it's pertinent to briefly share the motivation behind this investigation. Currently, the cube in my simulation represents a solid object, complete with physical walls where the velocity equals zero. However, the ultimate goal of my project is to analyze the forces acting on plants due to wind. Given that meshing a plant directly is impractical, I've opted to model a plant using a porous block. This means that in future simulations, the cube will no longer be a solid entity but a porous domain instead. Consequently, evaluating wall shear stress at the "wall" of the cube becomes infeasible since it doesn't constitute a physical wall per se, but rather an interface. This necessitates the evaluation of friction force via the velocity gradient. |
February 21, 2024, 17:45 |
Rep Power: 143 |
The force acting on a body is from both shear and pressure. Your comparison does not include the pressure component. Can you explain why is that?
UPDATE: Answered, the face is flat and you are looking at the force parallel to the plane, so the only force acting is shear. Are you calculating this in the solver, or in post-processing (CFD-Post or some other post processor)? The reason this is significant is that the solver has the full solution field including variable values at the integration points. The post processors only get the variable values at the nodes. This means post processors have a coarser mesh of variables to calculate from which will result in less accurate calculations. The implication is that if you want really accurate calculations you should do them in the solver and send the result to a monitor point. Then you will be doing the calculation on the highest resolution variable field.
February 22, 2024, 02:56 |
#3 | |
Fabio Asaro
Rep Power: 5 |
Your explanation is intriguing; I hadn't considered the enhanced accuracy during the solving process due to the connectivity among multiple integration points. However, upon monitoring both forces—one calculated using the du/dy approach and the other with the "Wall Shear X" variable (as detailed in the attachment)—I observed consistent results. This aligns with the outcomes derived from calculating values in CFX post within the table using the formulas provided in the first attachment to the post. |
February 22, 2024, 03:54 |
Rep Power: 143 |
I take it by your answer that you are calculating this in the post processor. If so, then it will be less accurate (so values will not precisely line up) as I described. Please put the calculations in the solver, send the result to a monitor point and rerun the simulation; then see if that improves accuracy.
February 22, 2024, 04:20 |
#5 | |
Fabio Asaro
Rep Power: 5 |
February 22, 2024, 05:32 |
Rep Power: 143 |
Strange, I would have thought there would have been a bit of a difference.
Can you repeat this comparison with a laminar flow model? The turbulent wall functions might be affecting things.
February 22, 2024, 09:37 |
#7 | |
Fabio Asaro
Rep Power: 5 |
1) Bc of oscillations at the monitor points in the laminar model, I implemented symmetry boundary conditions (only a quarter of original domain). 2)I excluded the eddy viscosity from the wall shear stress calculation, now defined as `areaInt(Velocity u.Gradient Y*(Dynamic Viscosity))@wallR`. Unfortunately, the discrepancy between the two values persists. |
February 22, 2024, 17:33 |
Rep Power: 143 |
For the laminar flow I would reduce the flow rate or increase the viscosity to make the flow steady. The oscillations are complicating the question.
But I suspect you are finding the difference remains in a laminar model as well. I cannot explain the difference, so you are going to have to do some exploring. Some suggestions: * What happens if you converge tighter? * What happens when you refine the mesh? * What happens when you change the advection scheme? * What happens when you change some of the lower level numerical parameters, eg interpolation schemes, Rhie-Chow etc? I would do this study on a laminar flow which is slow enough to be steady state so you do not have the complexity of wall functions and flow transients to deal with.
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
Wall shear stress due to roughness | tsram90 | FLUENT | 0 | October 27, 2014 04:28 |
Wall Shear Ansys CFX | king lui | CFX | 5 | June 2, 2013 19:59 |
wall shear force with VOF | Jürgen | FLUENT | 0 | July 27, 2007 06:28 |
Wall Shear force - any suggestions on turbulence modelling | Bo Jensen | Siemens | 1 | February 22, 2000 12:12 |
