March 11, 2008, 17:11 |
CFX routine PEEKCA Error
Hi everyone,
I am working with a steady state simulation in CFX 11, with CHT, solid domain rotating (Beta Feature), radiation. I have some issues over here. 1. Does anybody knows which should be the absorption coefficient "correct" values for steel, for example? I found in some literature that value to be 0.35 cm^-1. I have also the refractive index for some materials with its imaginary part (Extinction coefficient) and i found those values to be in order of 2e+9 to 7e+09 m^-1. Which value should i use? i am using 0 m^-1 but i don't trust in these results, because i want to do some material comparison to check the temperature profile. 2. When i turn on the option "Include motion advection" for rotating solids, the temperature just diverge. Is it right to ignore that feature? 3. I am also modeling airflow, with massflow at outlet. Unfortunately the solver is interpreting that outlet as part wall, part outlet, and it is asking me to switch to opening b.c. . Additionaly the velocity vectors doesn't appear to be correct. I've tried with scale mass flows option, shift pressure and constant. No one of them gave me trustable results. I have to increase the temperature of some walls near outlet and then the solver is working well, but that situation is not reality. Any ideas? 4. i got an error message in CFX, which is not allowing me to work in DesignXplorer, altough the solver is able to write the results file: ----------------------------------- ----------------------------------- Details of error:- Error detected by routine PEEKCA CDANAM = CVAR CRESLT = NONE Current Directory : FLOW/SOLUTION/TSTEP4/CLOOP1/ZN3/BELG12/IP ERROR #001100279 has ocurred in subroutine ErrAction Message: Stopped in routine MEMERR ------------------------------------ ------------------------------------ Thanks so much for any help, |
March 16, 2008, 12:43 |
Thermal Radiation Model with solids rotating
Hi everyone,
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
