Import Mesh from ICEM CFD to CFX
Like Tree1Likes
  • 1 Post By Rogerio Fernandes Brito
Old   March 19, 2008, 14:59
Default Import Mesh from ICEM CFD to CFX
Andre Almeida
Hi
I'm having some difficulties in obtaining a meshed geometry to solve with CFX. I have the geometry in Solidworks and, in order to import the geometry to ICEM CFD for meshing, I use the Parasolid format to export and read the piece geometry in ICEM CFD (Altough I think that might exist better ways of doing this, but I don't have experience...)
The problem is when I try to save the mesh in ICEM CFD, to read in CFX. I can't find the right format, can some one help?
It seems that ICEM CFD saves the mesh in .uns and the CFX does not read that format in the option Import Mesh ->ICEM CFD...
Thank you
Old   March 19, 2008, 15:12
Default Re: Import Mesh from ICEM CFD to CFX
CycLone
You need to set the output solver type to CFX (or CFX-5) and export the mesh to CFX. Within CFX-Pre, import the mesh as an ICEM CFD mesh.
The .uns format is only used by ICEM CFD.
-CycLone
Old   March 19, 2008, 17:54
solid works -> IGES file -> Import on ICEM CFD -> tab "Output", choose Solver "ANSYS CFX" and Save as file.cfx5 -> CFX_pre -> open the new simulation -> open file with the mesh -> choose the unit in "mm" and ready!
ghazal.hakemi likes this.
Old   March 19, 2008, 20:33
Andre Almeida
Thanks for the indications, I made it
Best Regards
Old   March 19, 2008, 20:37
You´re welcome!
Old   March 26, 2008, 19:00
kasim
Hi Andre
Can I ask how did you export the geometry from solidWorks to ICEM. When I export it solidWorks export the whole geometry as one piece. How did you make different parts in your geometery e.g. Inlet, Outlet, Walls etc. Thanks in advance for your answer.
kasim
Old   March 27, 2008, 08:36
Andre Almeida
I am constructing the geometries right now and haven't yet made any simulation. But after seeing your message I noted that I have the same problem. Can't really do a thing in CFX... Maybe some one in this forum knows the answer...
Advice, please
Best R.
Andre
Old   December 9, 2013, 02:39
Default I tried in ansys 13 in workbench but its not working
Bitte56
ARohit is on a distinguished road
Originally Posted by CycLone
;86976
-CycLone
I am working on ansys13.
I open cfx from workbench and when I try to import mesh made in icem cfd it doesnt read. I did all that saving solver as nastran and other option as ansys cfx.
cany some1 help me.?
ARohit is offline   Reply With Quote
Old   December 17, 2013, 16:26
xin
guxin7005 is on a distinguished road
maybe choose output solver as ansys cfx, and common structural solver as ansys.
guxin7005 is offline   Reply With Quote
Old   April 20, 2014, 15:31
Masoud
masoudmohammadian is on a distinguished road
If you still have problem, you can import ur geometry in ansys cfx, then auto mesh it there, after that u can save this mesh to ICEM with suffix 'tin'
masoudmohammadian is offline   Reply With Quote
Old   April 20, 2014, 15:33
Masoud
Dear friends
Hi
How can I export ICEM meshing to CFX?
Old   April 17, 2016, 04:23
Rocky
Rocky93 is on a distinguished road
Hii
I have selected AnsysCFX as solver but not able to find any save as option. There is "save project as" option. Which does save the file in .prj format. Please someone guide.
Rocky93 is offline   Reply With Quote
Old   April 18, 2016, 01:40
Lance
Lance is on a distinguished road
On the tab Output mesh/select solver: Ansys CFX. Then on the same tab: Write input.
Lance is offline   Reply With Quote
Old   April 18, 2016, 07:41
Rocky
Thank you Lance i have done that.
Old   April 18, 2016, 11:44
Rocky
Hi
While importing the ICEM CFD mesh file file to CFX, does the dimension of mesh change? Is it compulsory to import the mesh file in cm ? If i import with mm the dimension of geometry is different from the case if i import in cm. Is there any way to see the coordinate of components and dimensions of imported mesh in CFX-5? Please help.
Old   April 19, 2016, 01:20
Lance
Normally the length units are unitless in ICEM, but you can change to what ever you want in Settings/Model-Units. However, it's easy to change the dimensions in CFX if you got them wrong from ICEM. Right-click mesh, transform mesh, scale.
Old   April 19, 2016, 03:42
Rocky
Thank you once again Lance. It was very helpful.
I have one more doubt.While defining a domain of porous medium..we are required to fill are density. Can u please tell me how the density is calculated? I would really be grateful to u for this. please help.
mesh from icem cfd to cfx, how? Rogerio Fernandes Brito CFX 17 April 18, 2016 03:34
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 03:46
How to export 2-D mesh from ICEM CFD for CFX karimakhtar ANSYS Meshing & Geometry 13 November 3, 2011 09:36
How to import mesh from icem cfd to star ccm+ jopawipr ANSYS 3 March 21, 2010 14:18
How is ICEM CFD mesh file format? Seth CFX 4 March 2, 2008 17:22
