Monte Carlo - Surface "spots"??
Old   April 7, 2008, 11:09
Default Monte Carlo - Surface "spots"??
tsimon
Hi, When using the MC radiation model, modeling heat exchange by radiation between the walls, at different Temperatures. of a cubic box (ex.) with air, considered transparent - so using s-t-s radiation, the solution has no physical meaning. A series of "spots" or "points" of different temperature appear when seeing result wall temperatures. If using the DTM, the result has now physical meaning and seems to be correct. "All" parameters are the same except, of course, number of histories (tried till some million with the same error) for MC or number of rays for DTM.
Could anyone tell me what am I missing when using the MC model, some additional boundary definition??? Do I need a solid domain when using MC?? ´ Thanks, tsimon
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Meshing for Monte Carlo Radiation Zoran CFX 6 November 30, 2007 10:03
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
