Contour in CFX-Post using ratio of two quantities
Old   April 8, 2008, 15:07
Default Contour in CFX-Post using ratio of two quantities
Kushagra
Hi, In CFX-Post, I want to plot contour of 'Turbulence Kinetic Energy / Turbulence Eddy Dissispiation'? How to do it? I think I need to create an expression but I am not able to do it correctly. Please some body guide me. Thanks a lot, Kushagra
Old   April 8, 2008, 15:53
Default Re: Contour in CFX-Post using ratio of two quantit
CycLone
You need to create a Variable, not an expression (although your variable can be set equal to your expression).
-CycLone
Old   April 8, 2008, 16:03
Kushagra
Thanks cyclone. so should I just use '/' operator...could you please help me with the expression...I want to plot ratio of Turbulence Kinetic Energy and Turbulence Eddy Dissipation.... thanks so much, Kushagra
Old   April 9, 2008, 09:28
CycLone
Create a new variable and set it equal to your expression as you had it:
It's hard to believe, but you can just write equations where you need them. That's the power of CEL!
The reason expressions in the expression editor don't appear as plot variables is because variables need to be calculated and stored in memory. If Post did this for every expression it would be too expensive (and not generally needed). If you have an expression in the expression editor which you are interested in plotting, just add a variable and pick your expression in its definition.
-CycLone
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 14:53
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 12:12
CFX 11, post Anant CFX 1 June 24, 2008 11:03
ANSYS CFX POST State file Mechstud CFX 1 June 22, 2007 14:59
