flow separation problem
Old   April 15, 2008, 18:34
Default flow separation problem
bob
Hi
I am running a simulation of a 3d diffuser of a 4 degree angle.
The geometry has no sharp angles, the inlet BC is a velocity profile with suitable turbulence parameters. The outlet is area averaged static pressure of 0 relative to atmospheric pressure
I have run this with both SST and Reynolds stress models and i allways get flow separation when it should be attached.
Is thee any kind of setting in CFX (i am fairly new) that i may have missed
(have also tried total pressure at inlet with mass flow boundary at outlet and still separation)
Thanks bob
Old   April 15, 2008, 19:12
Default Re: flow separation problem
How far are you modelling upstream and downstream of the diffuser? What Reynolds number and Mach number?
Old   April 16, 2008, 00:43
bob
It's just the diffuser, no upstream or downstream modeling. The inlet initially has a very shallow expansion angle so is practically a pipe for the first 1/5th of the length then blends smoothly towards the outlet.
Re= 30,000 M=0.1
bob
Old   April 16, 2008, 19:53
You should model further upstream and downstream. If you don't know what is upstream make sure your inlet velocity and turbulence profile is correct. You will definitely need a domain or a pipe or something for the flow to go into downstream of the diffuser.
Old   April 25, 2008, 09:24
Felix
My experience with this kind of calculation is that the inlet b.c. has to be specified very carefully. If the flow isn't fully developped there is a probably a radial component to the inlet velocity. This would bring energy towards the boundary layer and give it robustness.
If you want to make a quick check, run the k-epsilon turbulence model with wall functions. In this case the wall function is likely to inaccurately rise the near-wall velocity and the flow will then stay attached longer. If it does so, it means that the k-epsilon sort of "hides" the fact that your inlet b.c. is not well defined and that you should have a radial velocity towards the wall in the inlet plane.
Then you'll know that you have to model further upstream, as Glenn pointed out.
Regards,
Felix
Jet flow problem.. PLZ help URGENT!! Vinayak CFX 1 April 3, 2008 18:02
good Cold Flow Results but problem with Hot Flow Rams CFX 2 June 13, 2006 03:30
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 08:04
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 03:24
