Multiphase non newtonian
Old   April 8, 2008, 13:39
Default Multiphase non newtonian
Jorge
I want to simulate a multiphase(liquid-solid) non newtonian fluid, the fluid has 40 % solid. How i simulate that. I have ansys 11.
Old   April 17, 2008, 10:22
Default Re: Multiphase non newtonian
M. Riffai
Hello Jorge,
Check Tutorial 11 "Non-Newtonian Fluid Flow in an Annulus". I believe they use a power-law approach "m=K*G^(n-1)" where m is the dynamic viscosity, G is the shear strain rate where they directly reference the CFX-Pre System Variable (sstrnr) in that case. K and n are parameters which are defined (with their units) within the CCL expressions along with the above equation.
Thanks.
Regards, M. Riffai.
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
multiphase model, water in air? bugra Main CFD Forum 10 January 2, 2010 13:09
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
