Hi there,
I want to plot the shock waves and the expansion waves of a flow around a flat plate. The simulation is done... How can I plot that inside CFX Post? I want to see the different angles. Thanks a lot! Mareike |
Have a look at tutorial 8, Supersonic flow over a wing. Glenn Horrocks |
hi glenn,
thanks a lot! ehm... what must i do to see the skin friction? |
This tutorial has a free slip boundary on the wing so you won't get any skin friction. You will have to rerun it with a no-slip wing to get skin friction. Also note to get accurate skin friction you will need a much finer mesh than the tutorials use. Glenn Horrocks |
Ayushman
Rep Power: 4 ![]() |
I have a query... How to plot shock wave position Vs time plot in ANSYS Fluent or CFD post-processor for any particular parameter like pressure or mach no. or density?
Rep Power: 143 ![]() ![]() ![]() ![]() |
This is the CFX forum. For fluent try the fluent forum.
But to visualise the shock waves, don't you just draw a cross section of pressure, density or velocity or something like that? Isn't that obvious? Or are you asking something else? (if so please explain what you are trying to do more thoroughly)
Ayushman
I performed a 2D simulation of the shock wave in shock tube using shock capturing method. Now I want to plot a graph of x-t (x co ordinate vs. time) for the shock wave in the shock tube. It was a unsteady with turbulent model, simulation using the Ansys Fluent. So, is there any way that I can plot x-t graph for the shock wave using the Ansys Post-Processing??
Thank You. |
Gert-Jan
Rep Power: 27 ![]() |
If you have Fluent .dat-files at intermediate time timesteps, then you can read these into CFD-Post using the Timestep-Selector-Icon. In this way you can plot the variables as a function of time and export graphs.
If you dont have intermediate files, then you have to rerun the case and make sure you save these. |
#9 |
Ayushman
In "x Vs t" plot, x is the length of the shock tube along which shock wave is moving.
#10 |
Gert-Jan
You can draw a line through your tube and plot the variable x as a function of length. This you can export to a .csv-file, Do this for every time step (using you timestep selector icon) and you will have multiple .csv-files. Plot them in a spreadsheet, ét voila.
You can also write a script to let Post read the .dat-files and write the .csv-files. Then it goes automatically. Possibly you can open multiple .dat-files into one Post session. Then you might get multiple lines in one plot in CFD-Post. I never tried. Please try. |
#11 |
I would export the pressure data (or density, velocity or whatever shows the shock clearest) as a CSV file and write a thing in python or matlab to find the shock and determine the x position. Then script it over all the time points and you have a shock position versus time curve.
#12 | |
Gert-Jan
With 'x' the length of the tube as a function of time..........?? Last edited by Gert-Jan; October 30, 2023 at 04:45. |
Frequency of a shock wave | Madhusanka | Main CFD Forum | 0 | April 24, 2011 11:38 |
Shock wave reflection | Zato_Ichi | OpenFOAM Running, Solving & CFD | 0 | April 13, 2011 14:35 |
Question about the shock wave | nucharin | CFX | 2 | January 27, 2005 04:44 |
Question about the shock wave in CFX software | nucharin | Main CFD Forum | 1 | January 25, 2005 08:26 |
shock wave propagation | Chetan | FLUENT | 1 | April 20, 2004 14:45 |
