ICEM-2D-Hybrid Mesh
Old   April 29, 2008, 03:11
Default ICEM-2D-Hybrid Mesh
icem-noob
Hi Folks!
hope someone is able to help me...
I've got an 2D airfoil which should have a hexa-mesh at the complete surrounding boundry. lets say for approx. 5 layers.
around that, my mesh should be the less exact tetra-mesh for the surrounding space.
if it's not really clear, check out following link... it's actually EXACTLY my problem!
http://www.ansys.com/products/icemcf...d/existing.htm
so... what I wanted to do is to block the airfoil and generate an O-Grid around these blocks. then I deleted all the external and internal block (copied to VORFN) so that the rest of my blocks would only be my O-Grid which should be associated with my airfoil spline. when I press on "pre-mesh" it shows me a few layers and thats it.
how do I generate a "normal" grid, as used in tetra?
and then .... how do I create a treta mesh which connects to my hexa mesh?
thanks dudes!
Old   May 24, 2008, 06:06
Default Re: ICEM-2D-Hybrid Mesh
Jeevan kumar
what is shown in the picture is not the hexa layers, they are prism layers followed by the tetra mesh. to create a prism layer, first you have to create the tet mesh and then define the prism layers. there is a tutorial for creating prism layer in ICEM, check it out
with regards jeevan kumar
Old   May 24, 2008, 07:28
Rogerio Fernandes Brito
U can use cfx meshing to create the tetra mesh (with prism mesh) and not the icem cfd!
Old   March 5, 2011, 16:44
Ugly Kid Joe
vmlxb6 is on a distinguished road
I am stuck where exactly icem-noob is stuck.
I am trying to simulate the flow over a cylinder.
I got the o-grid mesh around the cylinder but how do I get tri meshes in the surrounding region and also how do I connect the tri & o-grid meshes ???
Any kind of help is appreciated.
vmlxb6 is offline   Reply With Quote
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 08:16
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
Hex-Tet Mesh Merge in ICEM Tristan CFX 1 September 26, 2008 05:40
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
