April 30, 2008, 03:56 |
simulation Axial flow turbine using CFX
dear all i have axial flow turbine i want to simulate it and calculte the pessure and velocity distribution between the blades,if the turbine has 6 blabe under ahead of 40m and mass flow in 116m3/s.also what approperiate B.C for this case,and what can i get a convergence,also estimate the best number of nodes for good solution,how can i present the average static pressure at inlet and outlet. thanks dia
April 30, 2008, 05:30 |
Re: simulation Axial flow turbine using CFX
hi i read your message in thatfluid is water know inlet pressure:3.924bar or 392400N/m^2 avarage static pressure:total pressure+static pressure how much input power. ok
April 30, 2008, 05:38 |
how to calculate total pressure:static pressure+0.5*ro*velocity^2 ok
May 2, 2008, 02:45 |
hi
please tell me how to give near wall modeling conditons and where to give . I am simulating a linear turbine cascade. |
how to set up high temperature gas turbine flow simulation? | adam2008 | CFX | 1 | July 22, 2009 18:33 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 09:49 |
Flow study through Turbine Blade passage | Subrata | FLUENT | 1 | May 4, 2007 11:28 |
Turbine flow simulation data | Mohan Varma | Main CFD Forum | 3 | October 18, 1999 09:27 |
