Correct location for inflow and outflow boundaries |
May 7, 2008, 09:11 |
Hi
Im modeling a 2D pipe with a double backward step using air as the fluid. Needed to know whether there is any way to determine whether my inflow and outflow boundaries have been placed in the correct location. There is one inflow and one outflow. How can i determine this? And how could i correct it in Ansys 11.0 CFX-Pre? Thanks a tonne. Varun |
May 23, 2008, 03:43 |
Re: Correct location for inflow and outflow bounda
Varun,
If you are modeling a pipe which already exits, then you should follow the inflow, outflow as per your existing pipe geometry. And if you have to decide the inflow and outflow boundary, then you must have some crieterias such as uniform distribution of air, uniform temperature inside the pipe etc. in your mind for judgment. Now it's you who has to decide between this two. Regards Mehul |
outflow boundary condition | ravi_adepu | FLUENT | 11 | January 19, 2018 07:13 |
Outflow boundary Control Volume SIMPLE Help !!! | Mizerable | Main CFD Forum | 4 | August 22, 2011 13:00 |
Questions about OUTFLOW BC. | aleisia | FLUENT | 0 | March 5, 2011 21:42 |
Question about outflow boundaries and RSM turb. | George | Siemens | 0 | February 16, 2007 09:47 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 13:11 |
