A CFX SOLVER ERROR?
Old   May 20, 2008, 10:55
Default A CFX SOLVER ERROR?
frank
Hi,everyone I got a ansys cfx 11.0 like this:
Error in subroutine FNDVAR : Error finding variable DENSITY_FL1 GETVAR originally called by subroutine GET_MFLOIP_ZIF
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine GV_ERROR
Can any body tell me what is the reason?
thanks in advance. frank
Old   May 20, 2008, 12:24
Default Re: A CFX SOLVER ERROR?
Rogerio Fernandes Brito
did you give the information about the density for your material? If u´ve had created your own material, did u put this kind of information?
Old   May 20, 2008, 13:16
frank
Thanks for your reply. Yes, you are right. I create my own Variable composition mixture: Air Ideal Gas + H2 Ideal Gas. so I think there is no need to set density for this mixture. so I just create my own material "mix" under library tree as follow: thermodynamic state:gas mixture properties: Ideal mixture
thermodynamic properties: specific heat capacity: ideal mixture
When I try to set the equation of state to Ideal Mixture, an error will come out saying:"molar mass is missing and can not set equation of state"
where is the questions? please. thanks frank
Old   May 20, 2008, 14:17
once, i forgot to put the heat capacity Cp and i had an error and the cfx-solver stopped running.
Old   June 1, 2008, 23:30
Joby Kuriakose
I am getting an error like this...would like to know the reason for this:
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | c_fpx_handler: Floating point exception: Invalid Operand
Old   June 1, 2008, 23:33
Joby Kuriakose
I am getting an error in the CFX Solver:
Illegal faceset pair has been found
Would like to know the reason, and the possible Solution:
Thanks
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
