Problem of torque prediction in CFX
Old   January 11, 2009, 22:20
Default Problem of torque prediction in CFX
Patrick
Now I'm simulating an outdoor unit fan of HVAC. And I calculated it at three different speed 500RPM, 700RPM and 950RPM. The pressure rise of all three speed is reasonable matching the test data. As to the torque of blade, it is good at 500RPM. But at 700RPM the value of torque is about 15% over predicted. At 950RPM the torque is about 20-30% over predicted. The whole case use the same mesh and the turbulence model is k-epsilon. I checked the Yplus in Post and found it is about 12-27 at 500RPM, 15-38 at 700RPM and 20-50 at 950RPM. Anyone who have ever met this problem and how could I got a more accurate torque? Thanks.
Old   January 12, 2009, 19:17
Default Re: Problem of torque prediction in CFX
Have you done all the normal checks? I mean Mesh size, convergence, physical models, timestep etc.
Old   January 13, 2009, 00:06
Patrick
Glenn, I've checked all the things you mentioned. And I make sure the convergence is good. I do not take the mesh-independence test and I just gave the mesh size according my experience so I do not know if the case is mesh independent.Is it necessary to make some more mesh to test this? I'm wondering since the low speed case could give the right toruqe why the high speed case could not give the right toruqe? Is that related to the mesh or the Yplus or other things?
Old   January 13, 2009, 17:49
It is typical for a low speed case to run OK on a coarse mesh but a higher speed case requires a finer mesh. This is because the gradients get larger, boundary layers smaller etc. Sounds like a mesh sensitivity check on the high speed run is required.
Old   January 23, 2009, 17:56
CycLone
Patrick,
How are you determining the "right" torque?
-CycLone
Old   September 19, 2013, 05:44
Triloka Tankala
trilok99 is on a distinguished road
Originally Posted by Patrick
;91498
We have the same issue of torque prediction. Did you conclude anything from your study. I am also simulating HVAC outdoor unit fan.
Thanks in advance for your help.
Please reply at trilok99@gmail.com
trilok99 is offline   Reply With Quote
Old   September 19, 2013, 05:51
We have now written an FAQ on this: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Problem in coupling CFX and Ansys for fluid-thermal sim. Jordi CFX 21 March 1, 2017 05:03
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 10:00
CFX Casting problem: Can it be done all in one? jfasl CFX 1 September 14, 2010 03:14
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 09:48
