Flat residuals?
Old   June 11, 2008, 15:10
Default Flat residuals?
Ahmed
Hi
I am simulating a steady state flow in a box. It is a compressible flow. I am using total pressure at the inlet = 101326 and static pressure at outlet = 101325.
My problem is that my residual become flat after 20 iterations and I do not observe any change in them. How can I achieve convergence in a such case? Thanks in advance for your help.
Ahmed
Old   June 12, 2008, 10:01
Default Re: Flat residuals?
Dr. V. Kumar
1 Pa pressure difference seems to be too low to get the flow go through your domain.
Old   June 12, 2008, 10:23
Ahmed
Hi Kumar
Unfortunately, thats how things are. Is there a way to achieve convergence for this case.
The corresponding velocity for 1 Pa pressure is about 2 mm s^-1. It should make it to other side. Thank you
Old   June 12, 2008, 18:30
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   June 13, 2008, 05:26
Ahmed
Thank you Glenn. This is very helpful.
Ahmed
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 03:59
flat residuals shilpamkar Main CFD Forum 18 August 12, 2011 14:03
The flat profile of residuals Summer FLUENT 1 July 3, 2007 05:24
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
