angle stall for a wing
Old   June 30, 2008, 20:38
Default angle stall for a wing
Richard
Can CFX predict angle stall for a wing? (profile wing from naca 0015). Thanks before
Old   July 1, 2008, 05:35
Default Re: angle stall for a wing
JT
yes, just set up a transient case where the wing rotates or several steady state cases at different AOA's... keep an eye on the pressure profile in CFX-post
Old   July 2, 2008, 04:42
Default Re: angle stall for a wing ( for JT )
Richard
thanks JT for your information. but I have tried from angle of attack 10 degree until 50 degree but wing lift always increase from 10 degree until 50 degree not decrease at its stall angle (for naca 0015 it's about 15 degree). what's wrong? or I have misconseptions. thx.
Old   July 2, 2008, 18:21
This can be modelled but is very difficult to get accurate. Having said that if the flow is still attached at 50 degree AOA then your model is grossly inaccurate and you obviously need to check the physics and accuracy of your simulation.
Old   July 2, 2008, 20:44
Default Re: angle stall for a wing ( for Glenn Horrocks )
Richard
Thank's Glenn for your information. I need your help again. Where I can find theory about stall angel for wing? Can I find it in CFX manual?
Old   July 3, 2008, 01:49
For general information about stall angles for airfoils see a general airfoil textbook. There is also a lot of information on the web, try google.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Determining Stall Angle of 2D Airfoil Active.Aero.Fiero FLUENT 3 October 27, 2010 09:07
Airfoil at stall angle cfd_newbie FLUENT 10 February 5, 2008 11:33
Modelling flow over airfoil at near stall angle Kelvin FLUENT 5 June 6, 2007 02:00
Dynamic stall on circular wing Anton Lyaskin Main CFD Forum 1 November 4, 2002 06:47
