Why the velocity keeps rising??
Old   July 1, 2008, 13:49
Default Why the velocity keeps rising??
arkuk
Hi
I am running LES simulation with periodic boundaries. I am monitoring velocity at a point in my domain. I observe steady increase in my velocity. Why is that?? Any input will be welcome.
Thank you
Old   July 2, 2008, 18:08
Default Re: Why the velocity keeps rising??
Almost always this is due to the physics of the simulation you have defined, for instance a heat source with no heat sink so the temperature steadily rises.
It can also be caused by inadequate convergence.
Old   July 3, 2008, 09:44
arkuk
Hi Glenn
I am observing significant increase in my velocity. As a result my LES results look very different than my RANS solution. At the start of my siumlation I had a velocity of 2 m/s but now its almost 3.5 m/s. There has to be something here.
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
why velocity keeps rising?? arkuk FLUENT 0 July 1, 2008 13:50
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
