July 9, 2008, 04:52 |
cfx5remote was interrupted by the user
Hi
recently i can not run cfx in paralle model in MPICH model.but i can run it before.i have changed nothing. error message is : rm_28007: p4_error: semget failed for setnum: 0 A fatal error has occurred in cfx5remote on cn98: cfx5remote was interrupted by the user. An error has occurred in cfx5solve: The ANSYS CFX solver was interrupted by signal PIPE (13) No results file has been created. can any one help me ? thanks wayne |
July 17, 2008, 09:03 |
Re: cfx5remote was interrupted by the user
let me ask you something: if run it in PVM mode("PVM Distributed Parallel") it works? I am having the same problem and if I use PVN it works. but is too much slow... I am also looking for the solution of this problem. Ate, Carlos |
July 19, 2008, 08:44 |
Hi
i am not try the PVM distributed Parallel way.but i have tried the HP MPI,but it can only run with 2 nodes * 2cpu/node. i think it is problem of share memory. you could turn to the help of parallel run.and you could do the "ipcs" to check the share memory and semaphores,but i can not clean the share memory left over from an abnormally aborted previous ANSYS CFX computation. |
December 14, 2011, 08:15 |
#4 | |
Mina
Rep Power: 15 |
The ANSYS CFX solver was interrupted by signal PIPE (13) What did you do to solve it? |
collect User Experience about CFD softwares | dxw_CFD | Main CFD Forum | 12 | October 24, 2011 22:08 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 06:12 |
user routine, user funcion, or fortran compile effect on the memroy? | princeps11 | CFX | 1 | May 13, 2009 18:37 |
CFX 10 User Routine NOT in Fortran | Andre | CFX | 14 | August 8, 2006 23:03 |
particle user routines | Felix | CFX | 1 | July 24, 2006 12:32 |
