YPlus values
Old   July 23, 2008, 16:09
Default YPlus values
underGroundMan
I need to use SST model for my simulation, therefore I want to calculate YPlus values for my mesh. Is there an efficient way to do that OR do I need to set up the problem every time and run the solver to check to the values. YPlus is also a function of velocity, so in order to check YPlus how should I initialise my flow field.
Thanks in advance.
Regards
Old   July 23, 2008, 19:43
Default Re: YPlus values
rc2vo7
Google 'y plus calculator' and there are two of them, they're on this site somewhere too. Just provide Rn, ref length and desired Y+ and it will give you the dist to first grid point.
Old   July 24, 2008, 10:51
underGroundMan
Thank you rc2v 007.
Regards
low reynolds re turbulence boundary and yPlus values Thomas Baumann OpenFOAM Running, Solving & CFD 26 December 21, 2013 22:16
Yplus values Matteo CFX 3 December 4, 2008 23:19
YPlus values underGroundMan Main CFD Forum 2 July 23, 2008 17:14
YPlus Values and SST Model Jenny CFX 1 June 22, 2008 18:47
Yplus values for walls in CFX4.4 Forrest CFX 5 March 3, 2004 04:13
