restart a case with .trn file in command line way?
Old   October 10, 2008, 09:02
Default restart a case with .trn file in command line way?
wayne
Hi
every one ,i run CFX in commond line way to do some unsteady calculation,but the calculation was shutted down without saving .res file for the computer power was cut down.but it has some transition file (.trn) but i can`t start the case in the commond line way with transition file. i use the commond as following:
cfx5solve -def mycase.def -ini mytransition.trn
but it get errors as: error report by IO model iocntpen primary file failed
error from IO model while opening /myroot/mytransition.trn
how can i resolve it ???
thanks
yours wayne
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
