ICEM CFD 11tetra mesh
Old   October 14, 2008, 05:19
Default ICEM CFD 11tetra mesh
Hi
I have particular airfoil and I need to calculate air flow. I made very thin 3D sector (extruded airfoil on 20 cm) and built domain boundaries around this sector. So now I have very thin 3D box (about 11000 cm length and width and 20 cm thickness) What I want is to generate tetra mesh but I face a lot of problems. I guess this is because of very thin 3D box. Maximum size of tetrahedral element must be much more than 20 cm (about 500 cm) and mesher can't insert such tetrahedral element correctly. On the other hand minimum size must be about 1 cm near airfoil to catch all differencies in flow. Please advice me how to build mesh in my situation?
Old   October 16, 2008, 03:15
Default Re: ICEM CFD 11tetra mesh *NM*
jeevan kumar
Old   October 16, 2008, 03:18
jeevan kumar
hi am not able to understand the problem clearly. if you can post the image of the geometry, then i can help you.
Thank you
Old   October 16, 2008, 05:29
Hi
Unfortunately I'm not able to post image right now ((( Just imagine that you have very thin 3D box with XYZ-size (10000, 10000, 20). So X and Y are much more than Z. Also imagine that inside this 3D box (just in center) there is a blunt body (like cube) with XYZ-size (10,10,10). Now I want to build tetra mesh. To do this I set maximum size near blunt body to 1 and Global Size to 500 (size of tetra closer to planes which form 3D box). ... Mesh generation fails. Note that if I generate mesh in, for example, cube with XYZ-size (10000, 10000, 10000) everything is fine.... I suppose that the reason of failure is the fact that mesher can't build tetra inside 3D box with edge more than 20.
Old   October 16, 2008, 15:55
Charles
Yes, this will not work. But the more sensible approach would be to to build a small tetra mesh around the area of interest, and then extrude the faces of this mesh in your X and Y directions. Don't try to generate it in one go.
Old   October 17, 2008, 11:04
Hi
Could you tell me how to do this extrusion? And how to set such kind of area of interest around the body?
I also tried to build mesh around blunt body using blocking and actually I built it. But then I must build small tetra mesh around blunt body ans somehow to connect this with blocking mesh but I don't know how...
Old   October 18, 2008, 07:58
Charles
Your question is not actually very clear. Your first question makes it sound as if the grid really needs to be 2-dimensional with a 20 cm cell in the third direction. Your second description is different, it sounds as if you want a 3-dimensional grid with a thin third dimension. If your requirement is really for a 2D airfoil, like you originally said, it is much better to do a pure 2D grid (triangular if you really need that, but it sounds like structured quad would be better), and extrude that in the third direction.
If on the other hand, you really need a very thin 3D mesh, then the best option is to do a small refined region around your body using more or less isotropic tetrahedra, then take the boundary faces and extrude them to the far boundaries.
Old   October 19, 2008, 04:22
Hi
Ok, let me clarify. I meant second description and I want a 3-dimensional grid with a thin third dimension. Could you tell how to set (in outline) this small refined region around my body and how to exrude boundary faces to the far boundaries?
Old   October 19, 2008, 04:42
Charles
Build a small closed set of surfaces around your body of interest, and create a tetra mesh in there. Then take the outer faces of that mesh block and extrude them out to your real boundaries.
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 03:42
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 03:46
Loading previously saved mesh in ICEM CFD user0314 ANSYS Meshing & Geometry 1 September 20, 2011 12:46
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 03:54
