September 23, 2020, 08:29 |
Recover the Solver data
Meysam
Rep Power: 6 |
My solver hung after 195. Iteration. In my Cfx folder, I see just the Out.file and below files see photo: 2.PNG also, I can see my cluster is working, even I have closed the Workbench, See photo: 1.PNG Can I recover my solver data and produce the res.file? or How can I start the Solver through the actuall data ?( with Out.file and etc...) |
September 23, 2020, 08:35 |
Rep Power: 32 |
Unfortunately not. There is nothing left in that photo that contains any useful data.
It is probably best to add an automatic backup file every 50/100 iterations just in case it happens again. You have to start the simulation once again.
September 23, 2020, 08:38 |
Rep Power: 11 |
Do you set CFX to write backup files? Look like no. Search *.bak files in the working folder. If you find this file you can rename it to .res and use as result file.
If you don't find .bak or .res files then set backup next time, before solver launch. All current iterations results are lost. And I recommend running CFX in standalone mode, not from Workbench. It is much more easier to manage different files in Standalone mode. |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
How to read data from a table in the solver code openfoam | upuli | OpenFOAM Programming & Development | 0 | July 7, 2020 04:42 |
Validation Data for Riemann vacuum solver | Flexflix | Main CFD Forum | 2 | August 3, 2018 10:33 |
accessing solver data with UDF macros | Dushan | FLUENT | 1 | April 22, 2017 21:05 |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 04:46 |
