ICEM periodic boundary
Old   November 20, 2008, 07:30
Default ICEM periodic boundary
CG CHEN
Hi,all,
I would like to generate the tetrahedral grid by using ICEM. My problem is I have a pair of periodic boundaries and the grid generated on these two boundary surfaces should be same. But I couldn't not find such kind of functions in ICEM to satisfy my requirements. I'm a beginner in using ICEM. Thank you for your help in advance.
Old   November 20, 2008, 08:29
Default Re: ICEM periodic boundary
Ahmad Al-Zoubi
Hallo CG CHEN,
Go to Mesh ==> Global Mesh Setup ==> Global Mesh Parameters ==> Setup Periodicity.
Good luck.
Ahmad
Old   November 20, 2008, 08:46
CG CHEN
Thank you for your reply!
I found that function. But when I choose translational periodic, the only choice is "offset", I'm not sure if it is enough for set the periodic boundaries, for example, the computational domain is a cube and top and bottom surfaces are periodic.
Old   November 14, 2010, 07:09
Sangram
sangrampp is on a distinguished road
Originally Posted by CG CHEN
;90954
you should choose as offset whatever the dimension of the cube is.
sangrampp is offline   Reply With Quote
Old   October 10, 2011, 09:44
Siroos Azizmohammadi
s_azizmohammadi is on a distinguished road
Hi guys,
I am new user in ICEM CFD meshing. I wanted to create a periodic triangular mesh in a 2D rectangle. I used "Mesh ==> Global Mesh Setup ==> Global Mesh Parameters ==> Setup Periodicity" and translational one and set the offset as size of rectangle.
Now I have to define opposite edges to specify which edges should have periodic condition. I don't know how can I do that. I tried to create block but I don't know the different options over there.
It would be appreciated if somebody could give me some hint to solve the problem or share a documents that could help me.
Regards,
Siroos
s_azizmohammadi is offline   Reply With Quote
Old   October 10, 2011, 14:21
Edmund Singer P.E.
singer1812 is on a distinguished road
Put this in the Meshing Forum?
Try putting the edges into parts. I think you can use those parts as the periodic choices. I dont work with 2D ICEM much, but works fine for 3D.
singer1812 is offline   Reply With Quote
Old   October 11, 2011, 02:56
Ok. Thanks, I will do that.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
HELP,how to define the periodic boudary conditions using the icem mesh? dada1204 FLUENT 2 May 1, 2012 17:06
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
Periodic Boundary Condition Swapnil CFX 1 December 17, 2002 21:59
