December 31, 2008, 05:26 |
Memory error
Hi all,
This is the error I get ************************************************** ********** solver-pvm.exe - Application error The instruction at "0x039a178f" referenced memory at "0x1af7ca38". The memory could not be "read" ************************************************** ********** Any suggestions? Regards, VSB |
January 2, 2009, 04:43 |
Re: Memory error
I guess you made some mistakes on boundary conditions.
January 5, 2009, 05:31 |
Re: Memory error
whiz is right - it probably means you are incorrectly calling a CEL expression or giving a incorrect CCL value. Have a close look at the CCL you have written. Check it by running it through CFX-Pre. Glenn Horrocks |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
