June 1, 2011, 09:16 |
flux source at particular location(boundary)
Churamani Prasad
Rep Power: 14 |
Hi.
I need to find the derivative of a variale (reactant.molconc) at particular location(x=0.002) which i m able to do it and then specify two sources, NEGATIVE SOURCE at left of the location and POSITIVE SOURCE at the right of the location, where source is some simple function of the gradient of the reactant.molconc . The geometry is simple reactangle with a boundary at x=0.002 I thougt of a way but don't know(90% sure that it won't work) if it will work the part of the code i written is : DO ILOC = 1, NLOC IF (X(ILOC).GE.0.002 .AND. X(ILOC).LE.0.002 .AND. & Y(ILOC).GE.0.00 .AND. Y(ILOC).LE.0.001) THEN SOURCE(ILOC-1) = -(1e-9)*GRAD_PHI(1,ILOC) SOURCE(ILOC+1) = (1e-9)*GRAD_PHI(1,ILOC) END IF END DO but i m not sure if ILOC-1 will be just left of the location and ILOC+1 at the right of the boundary. The problem is how the vertices are assigned to NLOC.. Plz help on this...Suggest some other and better ways to do the same. |
June 1, 2011, 11:59 |
A.R. Baserinia
Rep Power: 16 |
No, it's not going to work. ILOC has nothing to do with the physical location of a vertex. More importantly, you cannot define a point or line source in the finite volume method. You should add your source like the "User Defined Momentum Source" example in the documentation.
June 1, 2011, 18:27 |
Rep Power: 143 |
Why can't you use the built in CEL gradient functions?
June 2, 2011, 01:58 |
Churamani Prasad
Rep Power: 14 |
@ Baserinia
Yes, I have read the "momentum source" from the documentation. But the unit of momentum source is kg m^-2 s^-2 and the unit i need is kg m^-2 s^-1. So, it is giving some error. Also there is only option of momentum source, no option of mass flux source which i need. |
June 2, 2011, 02:21 |
Rep Power: 143 |
Use a mass source then. And your comment about the momentum source shows your momentum source units are wrong.
.... And why not use the built in CEL gradient functions? |
June 2, 2011, 03:22 |
Churamani Prasad
Rep Power: 14 |
But even the mass source unit is kg m^3 s^-1, i need mass flux source kg m^2 s^-1
We are also trying other things and going through the built in CEL function too. Thanks |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
