Re-meshing in CFX11.0, one last time
Old   January 9, 2009, 17:08
Default Re-meshing in CFX11.0, one last time
Khaled M. Essa
Dear All,
I am conducting fluid-structure interaction simulations as part of my research. In my problem, the mesh deformation is considered 'severe', in the sense that the structural dynamics cannot be supported without remeshing. I know that CFX-11.0 has the Multifield option which can take care of a two-way FSI coupling (CFX-ANSYS). My question is, can you setup the problem such that once the mesh elements are highly distorted, the deformed geometry can be exported to Workbench for re-meshing? ANY suggestions/references/advice would be highly appreciated.
Regards,
Khaled
Old   January 11, 2009, 16:42
Default Re: Re-meshing in CFX11.0, one last time
I think this area has much better support in V12 if you can wait for that to be released. In the meantime it is possible to script something which monitors some form of mesh quality parameter and when it is excessive it stops the simulation, remeshes and restarts, interpolating the previous simulation onto the new mesh as the initial condition.
It is tricky to get working without manual intervention but possible. Should be much easier in V12.
Old   January 12, 2009, 10:13
Khaled M. Essa
Hi Mr. Horrocks,
Thank you for your response. I might not be able to await the V12 release. Are there any examples/references as to how to script an automatic remeshing operation in CFX? I have found a journal paper on cardiovascular simulations that utilized such a procedure, unfortunately there was no mentioning of any details. Any advice would be valuable!
Regards,
Khaled
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
