ICEMCFD - Prisms in a gap
Old   January 16, 2009, 10:45
Default ICEMCFD - Prisms in a gap
Andreas
Hey everyone,
in my geometry, there is a gap between a body component and the floor of about 1.5mm. The body is supposed to stand on the floor, so this gap must be as small as possible. For the tetra mesher, there are no issues - defining thin cuts works perfect. However when growing the prism layers there is an issue.
The total height of my prism layers is supposed to be 12mm, that is way larger than the gap. So I have expected that the gap will be filled completely with prisms. Unfortunately that is not the case. Instead, there are tetras between the outer most prism layer and the floor, which are totally skewed and make the CFX-solver to crash. Does anyone know how I force ICEM to fill this gap entirely with prisms and delete all tetras?
Thanks in advance.
Old   January 18, 2009, 18:24
Default Re: ICEMCFD - Prisms in a gap
This cannot be done. You will need to make it a different block and use hexa or manually generate a swept mesh.
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
ICEMCFD script files question hadj Main CFD Forum 0 December 5, 2007 09:06
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
importing mesh from icemc icemcfd 4 to icemcfd 10 James Willie CFX 3 July 7, 2006 13:19
IcemCFD 4CFX-How to fix domain Ahmed CFX 6 March 9, 2004 18:38
