How to sum the flow mass_Junction Box Routine
Old   February 5, 2009, 21:34
Default How to sum the flow mass_Junction Box Routine
Song
I'm doing a transient analysis of tank exhaust, the model is very simple, just a tank with a open. I need to know how much mass of air flow out from the open at every time step rather than calculating them after all steps.
Could somebody tell me how to use CCL or Junction Box Routine to sum/accumulate the flow mass at each step?
Thanks very much!
Old   February 8, 2009, 18:35
Default Re: How to sum the flow mass_Junction Box Routine
Setup a monitor point defined to be the massFlow()@Outlet or similar. For the total stuff left in the tank use a monitor point defined as mass()@Tank.
You can then view these values as a function of time as the simulation progresses in the Solver Manager.
Old   February 9, 2009, 11:51
CycLone
...i.e. you don't need a Junction Box routine.
Compressible flow through a box at low pressure nbulleid OpenFOAM 1 January 20, 2011 05:15
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
