GETVAR subroutines
Old   March 23, 2009, 10:59
Default GETVAR subroutines
Ahmad
cryogenicT is on a distinguished road
I'm using the subroutine GETVAR to couple a combustion code to CFX. I am a bit confused about the the different options of the argument ACTION (type of action taken by GETVAR):
1. RETURN
2. RELEASE
3. FIND
4. GET
I couldn't find any documentation for this subroutine.
Could anyone explain the meaning and the difference between these options?
Thanks
cryogenicT is offline   Reply With Quote
Old   March 23, 2009, 16:33
joey2007 is on a distinguished road
You should use user_getvar which is documented in the help.
In the user fortran course I took, they said that getvar is an internal call which is not recommended to use and therefore not documented.
joey2007 is offline   Reply With Quote
Old   March 27, 2009, 03:05
Zef
Zef is on a distinguished road
GETVAR can be used with three types of ACTION argument:
1. RETURN
2. RECALC
3. RELEASE
The first one simply returns the data stored in memory. The second one preforms recalculation of the certain data. Each call with RETURN and RECALC arguments must be supplied by the subsequent call of GETVAR with RELEASE argument.
I've never heard about arguments GET and FIND in function GETVAR.
2joey2007: Function USER_GETVAR have limited functionality and cannot be used in junction box routines. So if you want to calculate something in JB routine you have to use GETVAR instead of USER_GETVAR.
Zef is offline   Reply With Quote
Old   March 28, 2009, 09:12
You are right. However where it is not required user_getvar is easier to use.
getvar, return/release/find/get
Passing data/variables between subroutines Emmanuel Resch Siemens 1 August 16, 2007 12:44
How to use the routine GETVAR in CFX10. windhair CFX 3 April 5, 2006 16:21
Prostar Tables - Sub. for subroutines Xobile Siemens 1 November 16, 2004 23:38
user subroutines in newer versions Sheila Siemens 0 September 22, 2004 19:10
User subroutines Mir Siemens 10 May 4, 2002 16:16
