grid independence study in transition simulation
Old   March 27, 2009, 11:26
Default grid independence study in transition simulation
littlelz is on a distinguished road
i am just wondering what variables are supposed to be compared as we do grid independence study for a transition simulation. i Guess transition location on the body is supposed to be one of them, any other key variables?
many thanks
littlelz is offline   Reply With Quote
Old   March 27, 2009, 12:04
Reza
triple_r is on a distinguished road
Have you thought of an integral variable too? (like shear force on wall or something like that)
And also a very simple question, what kind of flow are you trying to simulate using the transition model? Because you know that the transition model in CFX has been tuned for flat plate problem, or external flows at best.
triple_r is offline   Reply With Quote
Old   March 28, 2009, 05:15
acturally, we are checking forces and moments too. but the problem is they are changing little, while the transition location change a lot. so I don't know if the mesh is independent or not.
for your info, we are doing transition simulation for external flow.
many thanks for your reply
Old   March 28, 2009, 10:02
Reza
I think as for some variables it is harder to achieve mesh independence than the others, you should at the variables that are very important to you, and the variables that you are looking to take out of the simulation.
If the main point of this simulation is to get transition location, then you need to work more on the mesh, and increase its resolution a lot, but if the only important thing (the outcome that you expect) are the forces, then you have reached mesh independence.
Old   March 30, 2009, 07:16
thanks a lot. i got your point and will try more refine mesh.
all the best
unstructured mesh grid independence for Fluent Shane Schouten FLUENT 0 October 11, 2006 16:50
grid independence sangam FLUENT 2 December 16, 2005 02:00
grid stretching function for jet simulation Bobby Main CFD Forum 0 May 29, 2005 13:46
Grid size and combustion simulation versi Main CFD Forum 4 February 16, 2004 06:42
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 08:24
