Diffuser inlet boundary condition problem
Old   April 4, 2009, 04:24
Question Diffuser inlet boundary condition problem
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I've got a radial compressor wheel, and after that a diffuser. I want to simulate only the diffuser. I've calculated the inlet velocity components numerically. It has a radial component and an axial component, but the axial is normal to every point on the inlet. If I choose "cartesian velocity component", i set the components in the global coordinate system. In "Cylindrycal vel. comp" the problem is the same. If I choose the "Normal speed" option, i can set the "axial" component, but the radial(which coming from the rotation of the compressor wheel) not. So I have to set an "axial" component, which is normal to inlet in every points, and a radial component, which is perpendicular to these axial components.
Thanks
Attesz
Attesz is offline   Reply With Quote
boundary conditions, compressor, diffuser, inlet, velocity components
inlet boundary condition swe704 FLUENT 4 June 3, 2009 16:58
Inlet and outlet boundary condition David Baker FLUENT 3 June 22, 2005 00:42
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
inlet boundary condition in k-e model Abhijit Tilak Main CFD Forum 1 June 2, 2000 09:42
