April 6, 2009, 04:25 |
FSI Simulation unsing ANSYS Multifield
Fritzl
Rep Power: 17 |
Hello everyone
At the moment I'm busy doing my bachelor thesis. I'm trying to simulate a Fluid-Solid-Interaction of a helicopter blade. As I am new to CFD I am probably not 100% aware of what im doing I have the following setup: The outer domain is a static domain which velocity is 0. inside is a dynamic domain which spins with 3000rev/min. in the smallest domain is the blade. The highlighted area is the fsi interface. The goal would be to see the equilibrium position of the blade. I have first tried to simulate it as a static structural problem. so the inputfile was set to be so. when i simulated it in cfx the blade wouldnt deform at all. so i also tried to use a transient simulation using a dynamic simulation within the input file. but then this happend (it only calculated about 15mins, then an error came) It looks as if the forces were much to high. I am not sure about my settings at all: When using transient setup, the initial conditions must be set. for the rotating domain, I used 0m/s initial speed, but the domain motion under general settings I set to 3000rev/min. would that produce a step, which destroys the blade? or why did that happen? actually I am not interested in the transient behaviour.. I'm only interested in the final position of the blade. Wouldn that be possible with a static structural simulation?? Please tell me if you need further information to help me Thanks for your help.. |
April 6, 2009, 16:55 |
Michael P. Owen
Rep Power: 17 |
Have you run a steady state CFX model to get a better initial condition? The initial forces on the blade will be very high unless you do this.
April 6, 2009, 17:40 |
Fritzl
Rep Power: 17 |
Could you explain what exactly you mean? I have tried to simulate it as a steady state and as a transient model. How do you mean "to get a better initial condition"?
fsi in ansys 11 | kantored | CFX | 5 | April 6, 2010 16:58 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
FSI using Ansys LS-Dyna and CFX | YY | CFX | 2 | April 9, 2008 06:40 |
Restart of FSI simulation | V. Kumar | CFX | 3 | July 20, 2006 13:23 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
