May 8, 2009, 19:43 |
Determine pressure
Michal
Rep Power: 19 |
Hi, I need help I have to determine outlet or inlet pressure in coolant chanel in turbine vane. I have the fallowing parameters on inlet: diameter, Reynolds number, mass flow rate and avarage temperature. The fluid is air ideal gas. I need this to add bundary conditions in CFX. If somebody know how to do it, or what anoter condition i can set please help.
Thanks and regards. |
May 10, 2009, 21:45 |
Rep Power: 143 |
This is a pretty basic question - have you done the tutorial examples, especially the ones on turbomachinery which are supplied with CFX? They are the best place to start. Glenn Horrocks |
May 11, 2009, 19:22 |
Michal
Rep Power: 19 |
Hi Glenn, and thanks for replying.
I know that it’s basic question but I’m new In cfd and it is my first project. I would like to set mass flow at inlet boundary conditions and static pressure at outlet but I cant calculate this pressure. In my work I use data from this experiment http://gltrs.grc.nasa.gov/reports/1983/CR-168015.pdf for Mark 2 profile. If it possible give me some directions how to do this, or what other boundary conditions I can set, having only those data. Regards |
May 11, 2009, 21:28 |
Rep Power: 143 |
As I said, the place to start is the CFX tutorials. For incompressible flows the outlet pressure is usually set to zero and pressure is offset by that amount. I have not had time to look at your document at the moment so I can't give detailed comments. Glenn Horrocks |
May 12, 2009, 03:54 |
Michal
Rep Power: 19 |
Thanks for your advice and i start doing those tutorials. Regards |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
