May 14, 2009, 05:51 |
Pressure boundary conditions
Rep Power: 17 |
Hello, all
I want to model a simple flow inside pipe, what I want to specify is the pressure at inlet. But there are some problem I do not really understand. The pressure is 3 atm When I set ref.pressure to 1 atm, and relative static pressure to 2 atm, I can get the results, but when I modify the reference pressure to 3 atm, and relative statc pressure to 0 atm, the solve stops in the first iteration, and no result is generated, why? Thanks all |
May 14, 2009, 18:26 |
Rep Power: 143 |
What type of flow is it? Compressible? Transonic? You will need to describe what you are doing more fully. Glenn Horrocks |
May 15, 2009, 00:35 |
henry wang
Rep Power: 16 |
In CFX, the ref. pressure is the environment reference pressure. because usually the fluid flow is in the nature condition, so ref. pressure is 1 atm.. As explained, if a fluid flows in a special pressure condition like fluid flow in a vacuum environment, the ref.pressure should be set as 0 atm. Or if you simulate a air flows in a very high altitude (the atmosphere is supposed as 0.5 atm), the ref. pressure should be set as 0.5 atm.
So if you set the ref. pressure as 3 atm, the outlet should be set as -2 atm to make the outlet is in a atmosphere environment. But usually we don't set like this. |
May 15, 2009, 04:00 |
#4 | |
Rep Power: 17 |
Thanks |
May 15, 2009, 04:02 |
#5 | |
Rep Power: 17 |
May 15, 2009, 04:34 |
henry wang
Rep Power: 16 |
if you set the outlet as opening type, you should always set the outlet pressure, the value can be various.
if the inlet pressure is 3 atm and the outlet pressure is P(any value) in your case, it's better to set inlet pressure as 2 atm, the ref.pressure as 1 atm, the outlet as (P-1) atm. if the outlet is not to atmosphere, you can define the value of inlet and outlet yourself. for e.g. if the inlet pressure is 3 atm, the outlet pressure is 1.5 atm, the environment pressure is 0.5 atm in your case, it's better to set inlet pressure as 2.5 atm, the ref.pressure as 0.5 atm, the outlet as 1 atm. |
May 20, 2009, 04:12 |
Rep Power: 17 |
Thanks, the key point is the outlet condition. I got it.
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
Pressure Boundary Conditions | Dave | FLUENT | 2 | June 8, 2009 17:05 |
Pressure Boundary Conditions | John S | FLUENT | 1 | September 30, 2008 01:01 |
pressure boundary conditions | A.Shaija | Main CFD Forum | 0 | June 30, 2006 00:51 |
How to Define Pressure Boundary Conditions? | Sheenu | Main CFD Forum | 4 | May 12, 2000 12:52 |
