June 7, 2009, 15:52 |
Wall Heat Transfer Coefficient
hello
can anybody tell me, how CFX is calculating the wall heat transfer coefficient. Is it different from the following relation h=Q/(wall temperature-Bulk Temperature) where Q= heat flux h= heat transfer coeff. thank you.. |
June 8, 2009, 06:55 |
Rep Power: 143 |
Yes, that is correct. Note that by default CFX locally calculates the Bulk Temperature so it is not constant. If you want to compare the h from CFX to literature values you will probably have to use the expert parameter to fix the Bulk Temperature to a value. Glenn Horrocks |
June 8, 2009, 07:46 |
Thank you very much Glenn
July 14, 2009, 22:25 |
Jack
Rep Power: 16 |
Is this for transient or steady state regime?
BOILING HEAT TRANSFER COEFFICIENT | John | FLUENT | 1 | September 4, 2013 07:57 |
BOILING HEAT TRANSFER COEFFICIENT | John | CFX | 3 | April 4, 2012 17:50 |
facing problem in heat transfer coefficient | dhiraj | CFX | 1 | May 7, 2007 09:08 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Wall Heat Tramsfer Coefficient - UDF | Greg Perkins | FLUENT | 0 | June 25, 2001 00:31 |
