transiet analysis error when applied more than 10 s
Old   June 11, 2009, 01:07
Default transiet analysis error when applied more than 10 s
muhammad irham mahfud
memahfud is on a distinguished road
hi guys,
I have problem, when i applied more than 10 s for transient analysis error occurred. if you have solution or advice please share to me.. it will helpful
thanks in advance
memahfud is offline   Reply With Quote
Old   June 11, 2009, 06:35
Here's my advice - explain what you are trying to do and what error you are getting. Put the output file on the forum as an attachment. Then we have some chance of being of help.
Old   June 11, 2009, 10:55
Hi Glenn,
I want to know pressure rise in cryogenic storage system (vessel) cause heat flux in the system. i applied multiphase fluid (liquid nitrogen and air ideal gas). i attached the out file. this setting work when i applied time duration:10 s.
thanks
Old   June 11, 2009, 11:59
ckleanth's Avatar
George
ckleanth is on a distinguished road
if I was simulating a cryogenics storage system and I was interested in the heat flux propagation within the system I would use the nasa polynomials for the involved fluids
didnt check the physics thoroughly yet but mesh expansion is 1199.8 ! - have you checked the mesh quality?
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   June 11, 2009, 18:42
Nobody has time to do detailed analysis of your simulation, especially a multiphase simulation. But I have noticed the error is divergence of the linear solver - this simply means your simulation diverged big-time. My comments:
1) Start with a simple simulation and add the physics one bit at a time. If you start with the full complicated thing it will never converge.
2) George's comment about mesh quality is important - that may be causing the convergence problem.
3) The documentation has lots of suggestions about getting convergence. Try a smaller initial timestep, double precision, a better initial guess (maybe run a steady state model first) are all things to look at.
Old   June 11, 2009, 20:21
First, i want to say thanks to you guys,its very helpful. i am new comer using CFD programs.
one more question, does CFX capable to solve evaporation without flow? as i know CFX based on navier stoke equation.
thanks
Old   June 12, 2009, 02:39
ckleanth's Avatar
George
you will have flow just it wont be forced (buoyancy)
Top 4 tips
Old   June 16, 2009, 22:00
do you have other tips for evaporation in the closed system? i attach again my last result..
thanks
Old   July 14, 2009, 23:12
can you give me good materi about nasa polynomials?, thanks
Old   July 15, 2009, 02:51
ckleanth's Avatar
George
nasa polynomials are polynomials that people use to model the energy state of a particular fluid/gas (cp, enthalpy, entropy) at elevated or subcool temperatures. there are two versions i think the older one with the seven coefficients (the one that cfx uses) is mainly for temps between 200[K]-5000[K] for more information check the nist website and prof Burcat website to check for data in the subcooled range.
Top 4 tips
FSI Transient Thermal Analysis Abduri CFX 1 January 1, 2017 22:54
Fan Boundary conditions with external analysis Rob FloEFD, FloWorks & FloTHERM 1 February 10, 2009 00:04
Questions on Analysis Controls and Runtime Control Arnab Siemens 1 October 26, 2004 09:47
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 12:58
