Different temperature on boundary fluid-solid in CFX |
June 24, 2009, 09:30 |
Michal
Rep Power: 19 |
I have problem and need help. I do CHT simulation of flow around turbine vane and use SST model with and without turbulence transition and K-Omega model. I create line on boundary fluid-solid and check temperature. The temperature on solid side is different from this on fluid side. The difference is about 5%. My question is why, because those value suppose to be equal. I add chats. Thanks in advance |
June 24, 2009, 18:49 |
Rep Power: 143 |
For CHT simulations you should add imbalances as a convergence critereon in addition to the normal residuals. What imbalances have you converged to? Glenn Horrocks |
June 25, 2009, 16:11 |
Michal
Rep Power: 19 |
thanks for so fast reply. my settings for convergence criteria are: Residual type- MAX, Residual target- 0,00001. In expert parameters I didn’t mark imbalance normalization type. Regards |
June 25, 2009, 18:50 |
Rep Power: 143 |
As I said, a CHT simulation can have high imbalances (which leads to temperature imbalances) but well converged residuals. That is why you should also use imbalances as a convergence critereon for CHT simulations. It is on the solver tab in CFX-Pre (not an expert parameter). Glenn Horrocks |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
why is solid temperature same as fluid temperature on flow simulation ? | qihongming | FloEFD, FloWorks & FloTHERM | 0 | May 26, 2009 08:57 |
about compresive phase | James | CFX | 10 | September 12, 2006 03:16 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
