in - pressure, out pressure, is that make sense?
Old   July 1, 2009, 15:01
Default in - pressure, out pressure, is that make sense?
Marteusz is on a distinguished road
Hi everyone,
I want to simulate a flow through Bosch Rexroth directional valve. I modeled geometry. I want to obtain nominal flow rate through valve.
I have found how companies determine it.
This quotation from Bosch rexroth documentation from their website.
" No norm exists for the term “nominal flow rate”. To obtain a clear numerical value, Rexroth has defined the following:
Inlet pressure: pabs = 7 bar
Differential pressure: ∆p = 1 bar
Medium temperature: TM = 293 K (20 °C)
Humidity: Φ 0 %
Flow rates are indicated in volumes per time unit. The volume refers to a
normal state valid for pneumatics according to ISO 8778, and this is as
follows:
Pressure: p0 = 100 kPa (1 bar)
Temperature: T0 = 20 °C
Relative humidity: Φ 65 %
In order to identify the flow rate q as a slack volume, the acronym ANR
(Atmosphère Normale de Référence) can be added after the unit.
Example: q = 12 dm3/s (ANR)"
According to this documentation, I have asssumed reference pressure 1bar, 6 bar pressure at inlet, and 5 bar at outlet.
Ansys CFX gave me mass flow at outlet q = 0.00743 kg/s and i divided it by 1,18kg/s (density in nominal state) and I multiplied it by 1000 and 60 to determine nominal flow in dm^3/min.
But unfortunately results are about 4 times less than from technical card about this directional valve.
Did I simulate this valve in proper way? Why there is so big difference?
Thank you for your help
Mateusz K.
Marteusz is offline   Reply With Quote
Old   July 1, 2009, 16:08
ckleanth's Avatar
George
ckleanth is on a distinguished road
1) I didnt understand what you meant about the operating conditions that valve was tested. until thats clear (at least to you) i dont think you will ever find the solution
2) you said many words but nothing on how you modeled the valve in cfx (however find the answer to (1) first ) i presume it was steady state? did you assumed an isothermal state ?
3) read the "recommended configurations of boundary conditions" in the cfx manual.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   July 1, 2009, 17:06
1) operating conditions, They assumed 6bar at inlet and 5bar at outlet
2) yes it is steady state analysis, and I applied compressibility of flow by assuming Ideal Gas
Old   July 1, 2009, 20:28
Thumbs up
Jack
rogbrito is an unknown quantity at this point
Hi Sir,
is it possible to do an experimental analysis (only one Sir) with this valve? After that, u can do your (several) simulations with these CFD tools.
Rogerio.
rogbrito is offline   Reply With Quote
Old   July 7, 2009, 11:28
John is on a distinguished road
Defining pressure BC on both inlet/outlets does not make sense to me. You need some other BC conditions to make the problem closed.
John is offline   Reply With Quote
Old   July 7, 2009, 11:32
Timon is on a distinguished road
Total pressure in, static pressure out is fine...
Timon is offline   Reply With Quote
Old   July 15, 2009, 14:33
look at this article
http://www.abcm.org.br/symposiumSeri...SSM3_IV_05.pdf
especially at the end of section 2.3 and look how they apply bc. I aware that static pressure at in and out is not appropriate.
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Venturi tube results make no sense Paul FLUENT 1 June 17, 2008 14:09
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
