July 8, 2009, 05:16 |
Analysis for bake-out of a structure
Anna Encheva
I have to prepare a model - about 40 tons in reality with many cooling channel for bake- out analysis, which means - the structure should be heated from room temperature to a temperature of 240 deg.C. by using a fluid, either water or gas. The result should be which is the shortest time to which you can bring the structure to 240 deg.C and by which flow rate, pressure, etc. I have to play around with different fluids, different pressures , maximum allowable is 40 bar, and different mass flow rates. In this case which should be the most robust initial conditions I have to apply and how can I get from the results the pressure drop as well - the cooling channels in the whole structure are with many curvatures, bendings, etc. Thank you for the advices |
July 8, 2009, 07:38 |
Rep Power: 143 |
The documentation discusses robust boundary condition combinations. Have a read. It is trivial to get the pressure drop in CFD-Post, just calculate the areaAve pressure (or total pressure usually) over the inlet and outlet boundaries.
Glenn Horrocks |
July 8, 2009, 18:32 |
George
Rep Power: 18 |
if you're on about optimising a design or a procedure then yes cfd is what you should be doing.
however to be honest i think you itend to use the wrong software for the job.. from the description of your problem i think you'd be better off on doing "what if" analysis with 1D fluid/thermal software like flowmaster or you could investigate the posibility to use modelica (open source)
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
New ANSYS forum structure, what do you think? | Peter | FLUENT | 10 | February 6, 2009 04:07 |
New ANSYS forum structure, what do you think? | Peter | CFX | 5 | February 4, 2009 11:59 |
Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 17:46 |
Is CFD Science or Art ? | John C. Chien | Main CFD Forum | 36 | October 5, 1999 12:58 |
E-Z question about Von Mises stress | Andrew Epp | Main CFD Forum | 4 | September 17, 1999 02:11 |
