August 6, 2009, 18:16 |
turbulence model in CFX, seperated flow
Faruk Bhuiyan
I am doing open channel flow simulation (hydraulically rough boundary) with obstructions on the channel bed. Seperation of flow and reverse circulatiion zones were observed in laboratory. I have tested several turbulence models in CFX. With a sufficiently fine mesh k-e models results such flow seperation. However, with k-omega based models (SST, BSL EARSM) and RSM models dont show any seperation. Any comment/experience on that with CFX would be appreciated. Regards Faruk |
August 6, 2009, 18:39 |
Rep Power: 143 |
Well, you should have a detailed look at the qualities o the various turbulence models and of the flow itself and try to work out why the difference. k-e is known to fail in rotating flows but I don't think that's an issue here. SST would be my default option for turbulence so I can't explain why it did not capture the separation - are you sure you have all the accuracy issues sorted out, eg mesh, timestep, convergence? The RSM models in my experience tend to show earlier separation than the others so this result is puzzling. If the separation is transient with large vorticies like a bluff body then you may have to consider DES/SAS/LES approaches. Glenn Horrocks |
August 7, 2009, 06:29 |
Pratik Mehta
Rep Power: 17 |
I think there is seriously something wrong. What is the Re number of your system . Did you check your y plus values . Kindly check your .ccl file for boundary step up . I am sure you would get some hints from it . Best of luck Pratik |
August 9, 2009, 23:28 |
boundry layer
dss
Rep Power: 16 |
Hi:
1\there will be boundry layers in your calculation by mesh size. 2\You should choose good turbulent model which can calculate fluctuating pressure. I suggest you can choose LES or SAS. |
cfx, seperated flow, turbulence model |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
turbulence model fr Core annular flow | anup | FLUENT | 10 | November 7, 2007 02:52 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
Algebraic Turbulence Model for 3D flow | Dmitriy Makarov | Main CFD Forum | 0 | June 28, 1999 01:40 |
Turbulence model in flow driven by surface tension | Z. ZENG | Main CFD Forum | 7 | April 28, 1999 07:18 |
