Difference of multicomponent and multiphase homogenous flows |
October 14, 2009, 10:35 |
Lukasz
Rep Power: 17 |
Hi all - I have partly theoretical partly practical question.
1) What is a difference between multicomponent and homogenous multiphase flows? Assume I have 2 fluids of different densities (fe. water and methanol), no mass nor energy transfer between. Looking through the CFX documentation I see that simulating it as multiphase homogenous flow it solves for volume fractions, after that calculates density (where? mean density?) and than solves momentum eqations. If it is multicomponent than it solves for mass fractions, after that calculates mean density and momentum and so on in the end. Am I right? Where is difference? Is in "multiphase version" density taken from material properties and than the momentum equations are solved with these densities without calculating mean value? 2) Assume these two luquids are in the long pipe with gravity. In case of simulating it as multiphase homogenous I see fast stratification. In case of simulation as multicomponent I see no stratification, OR VERY SLOW. Does it mean that in case of multicomponent treatment there is only signle "mean" (mass fraction-weighted) density and because of that it is non possible to stratify mixture? Thanks for all answers because it makes me confused since quite long. Luk |
October 14, 2009, 17:31 |
#2 | ||
Rep Power: 143 |
Yes, a multiphase model (eg air and water) are likely to separate very quickly. I am pretty sure buoyancy also works with multi-component models - but keep in mind the separation occurs at a microscopic length scale so is likely to be slower than the multiphase approach. |
October 15, 2009, 03:53 |
Lukasz
Rep Power: 17 |
Thanks Glenn,
Now it seems for me that I understand this Assume that mentioned flow in the pipe. It seems to be like this: 1) If we define it as multiphase homogenous mixture and we set volume fractions of inlet as 50%/50% than the gravity acts in the moment and stratifies mixture because 50% of volume (fractions) are occupied by ingridients of different densities. Thats why multiphase homogenous stratifies in the moment. 2) If we define it as multicomponent and we set mass fractions of inlet as 50%/50% than the fluid has equal (mass-weighted) properties and will not stratify or stratify very slowly in case of small inhomogeneities. Thanks, Luk |
October 15, 2009, 06:21 |
Rep Power: 143 |
Be careful comparing the separation rates. The density difference between air and water is around 1000, such as is commonly modelled in homogeneous multiphase models. Multicomponent mixtures are commonly used for mixtures of gases (eg O2+CO2+N2), and the density differences between these components is much smaller.
So the separation speed of a water/air mixture is much faster than a O2/N2/CO2 mixture simply because of the larger density difference. |
October 15, 2009, 08:04 |
Lukasz
Rep Power: 17 |
Yes, of course.
Thanks, Luk |
September 30, 2012, 03:21 |
prishor p k
Rep Power: 13 |
hi all,
i am doing the simulation of gasification in Fluidized bed reactor. there are four components air, steam, biomass and sand.. my doubt is that can i consider this problem as 4 phase flow or consider as multi component 2 phase flow (gas-solid flow).??. please help me. thanks in advance, prishor |
October 1, 2012, 07:41 |
Rep Power: 143 |
How can this be a 4 phase model when there are only 3 phases (solid, liquid, gas)?
This should suggest the answer - the air and steam are both gases, so these are probably bets modelled as a gas phase multicomponent mixture. The two solids are modelled as two different solid phases. |
October 1, 2012, 11:37 |
prishor p k
Rep Power: 13 |
thanks Glenn.
you are saying the two solids can be treated as different phase even if they both are solids rite.?? how can i input both air and steam into FLUENT as components of gas phase. |
October 1, 2012, 19:00 |
#9 |
Rep Power: 143 |
If you are using Fluent then you are on the wrong forum. This is the CFX forum.
April 2, 2013, 10:35 |
shock tube problem
#10 |
srinath
Rep Power: 13 |
If I have a shock tube of Driver gas 'helium' and Driven gas 'air', is it multi-component flow. If this is the case will mixing take place at large time scales and contact surface disintegrate? How to define a multi component gas? |
April 2, 2013, 18:43 |
#11 |
Rep Power: 143 |
Have a look at the CXF tutorials on how to specify a multi-component gas.
multiphase multicomponent physics | ckleanth | CFX | 3 | June 4, 2009 20:15 |
multiphase and multicomponent flow | charles | CFX | 2 | December 18, 2008 21:34 |
Multiphase multicomponent system | David | CFX | 0 | January 15, 2004 20:59 |
multiphase or multicomponent.... That's the probl | july | Siemens | 1 | March 7, 2002 02:27 |
Multiphase or Multicomponent | Pandu Sattvika | CFX | 10 | January 7, 2002 04:40 |
