calculate time scale for mesh deformation analysis |
October 23, 2009, 05:54 |
wilsonbrad
Am performing pressure relief valve analysis, the problem setup is similar to tutorial 21.I did not find any difficulty while perform tutorial 21.Though I use same boundary condition for my case,after two iterations getting overflow error .. The geometry have clearance between piston and outer surface of the valve is 0.039mm (39 micron gap).
October 23, 2009, 06:44 |
Rep Power: 143 |
Overflow errors usually mean the solver has diverged. This could be due to poor mesh quality, unphysical boundary conditions or poor numerics. To address these issues:
1) Check the mesh quality when it is diverging. If the quality is poor you will need to revise your meshing. 2) Check that the boundary conditions you have are correct. Does it converge if you use a stationary mesh? It will need to converge with a stationary mesh before it will work with a moving mesh. 3) Use a smaller time step or ramp the pressure up to the full pressure over a period of time. Also check your convergence tolerance is OK. |
Time Scale in Fluent | Andrew | FLUENT | 0 | April 20, 2009 01:24 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
time averaged heat transfer in oscillating flow | Matthieu Ubas | Main CFD Forum | 2 | November 5, 1999 14:20 |
