December 6, 2009, 23:50 |
Velocity Profile as an Initial Condition
When carrying out a transient simulation, is it possible to input a .csv velocity profile as an initial condition for the entire domain?
December 7, 2009, 00:07 |
clarification
that is to say - I have a 2D velocity profile in the XY plane. This profile represents the flow within a circular pipe (drawn from a circle in the XY plane and extruded along the z axis).
The velocity profile is constant in the Z direction. (i.e. if taking a cross-sectional XY plane slice for any value of Z, the profile should be the same). |
December 7, 2009, 02:45 |
Arda Ersan
Hello ylm054,
I think you can do this with using Initial Tab under Domain Window. You have to use an expression which symbolize velocity profile. Then use this expression in Initial Tab under Domain Setting Window. Be careful you can't use any component of velocity as a variable in other component of velocity. For example; x_vel=(2*12.5+y/1[m])*1[m/s] expression defines x_vel as a function of "y". If you write "x_vel" to initial contidions/velocity/x component, CFX will give an error. So you can't use a component of velocity as a variable in any other component of velocity. Good Luck |
December 7, 2009, 04:33 |
Rep Power: 143 |
You can use your 2D data to generate an initial condition. Use the 3D interpolation function. If you can describe your points as a CEL expression or some 1D interpolation that is better but if they don't work use a 3D function.
December 7, 2009, 19:48 |
CFDman: "You have to use an expression which symbolize velocity profile. Then use this expression in Initial Tab under Domain Setting Window."
Is it possible to enter the profile without using an expression? Since CFX doesn't support bessel functions, I dont really think this is an option. ghorrocks: You can use your 2D data to generate an initial condition. Use the 3D interpolation function. If you can describe your points as a CEL expression or some 1D interpolation that is better but if they don't work use a 3D function. Once I have a 3D function how do I actually set it to be the initial condition over the entire domain? I get a bad value error when I type the function into the intialisation>cartesian velocity>w velocity box. |
initial conditions, velocity profile |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
MRFSimpleFOAM goes divergenced! | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 19, 2009 02:11 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
