eren
Rep Power: 0 ![]() |
hello all,
I 'm new in cfd,... in manual help ansys cfx with sample static_mixer mesh.gtm, how to make inlet and outlet because when catia design (static_mixer) import to cfx inlet and outlet there is nothing? thankyou so much all... |
Roland Rakos
Rep Power: 17 ![]() |
I don't understand your question, I try to help you... 1.step define a geometry (in Catia, ProE, DesingModeler etc.) 2.step Mesh generate (for example: with ICEM CFD or CFX Mesher) Here you can define the part names (inlet, outlet, walls etc.) Finally export the mesh to CFX 3.step Import the mesh file to CFX. If you have defined the part names properly, than these will appear in CFX. Finally based on the part names you can defined the boundary conditions... Regards Roland |
#3 | |
eren
make inlet outlet |
Passing Average Temp from Outlet to Inlet | Steve Scotts | FLUENT | 1 | August 27, 2008 05:02 |
mean velocity change from inlet to outlet | ro | FLUENT | 2 | April 19, 2008 13:37 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
recirc tank, inlet outlet conditions | david | CFX | 1 | May 22, 2007 03:23 |
Inlet & Outlet Boundary Conditions | dhananjay | Main CFD Forum | 2 | December 21, 2006 10:03 |
