January 5, 2010, 21:05 |
CFX wall heat transfer coefficient
Rep Power: 16 |
Dear all,
I would like to transfer the wall heat transfer coefficient (HTC) from CFX into ANSYS WB to perform a thermal analysis with fluid cooling. i understand i need to check how the HTC is computed in CFX, whether it is using near wall temperature or ambient temperature. how can i check this setting please?
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
January 5, 2010, 21:33 |
Tristan Burton
Rep Power: 17 |
I always get the following message in my .out files. I think it answers your question quite nicely:
+--------------------------------------------------------------------+ | ****** Notice ****** | | Wall Heat Transfer Coefficient written to the results file uses | | "Wall Adjacent Temperature" for the bulk temperature. If you want | | to override the bulk temperature then set the expert parameter | | "tbulk for htc = <value>" | +--------------------------------------------------------------------+ Tristan |
automatic way of calculating actual heat transfer coefficient | Hashmi | CFX | 4 | July 26, 2012 06:54 |
BOILING HEAT TRANSFER COEFFICIENT | John | CFX | 3 | April 4, 2012 17:50 |
Heat transfer coefficient from CFX | Sulfi | CFX | 18 | March 24, 2011 15:47 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
CFX - wall heat flux | divarano | CFX | 2 | December 4, 2006 16:14 |
